Sequence Matters
Sequence Matters
1. Confirm all prerequisites are complete.
2. Install plugs and bypass hoses as shown.
3. Connect nitrogen bottle as shown.
4. Run the pressure up to full value.
5. Test all joints for leaks.
Important: Don't run the pressure up to full value right away. Go up to a small value first.
RE: Sequence Matters
#) Remove (insert name of component)
in the step by step instructions in car maintainance manuals to find out after the part is off that it cannot be re-fitted without a new widget being installed along with it, in a foot note. Leaving me without a fully functional vehicle to fetch said part.
I'm a sucker for not reading the whole step by step before trying, I would have been the one who burst the worn hose / something more serious.
Designer of machine tools - user of modified screws
I now have to re-read what I wrote for a viscometer installation some 10-12 years ago and see if I did indeed get the sequence correct for pressuring and bring to operating temperature.....
Phew! I did.
I see the manual (with lots of illustrations and minimal text) has stood the test of time. It still includes the adapted Windows clip art that came with Windows 98.
Mind you, barring a catastrophe, once written most manuals seem more resistant to change than the products they describe so that may or may not be a source of comfort.
JMW
www.ViscoAnalyser.com
Once had a teacher give us True/False test.
To me every answer was TRUE. Sure enough, after he gathered up the tests - he said "Gentlemen (all boy school)- those were ALL true"
You have never heard so much moaning, groaning and cursing in you life!!
However, I had screwed it up alright. Back to the parts store for a new piston assy.
The step-by-step instructions appeared to have ended at the bottom of the page so I didn't turn the page. Sigh...another learning experience.
I put MY "Notes" at the beginning of the instructions.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Technically, the glass is always full.
Ten minutes later - she had it where I wanted it!!
KIDS these days - can't live with them - can't live without them!!!
JMW
oh, been there done that. Had an 81? escort station wagon bought new, approaching 60k miles and decided to do the timing belt replacement before we went on a long vacation.
Factory manual, step by step, scheduled maintenance section. Had to weld up some special wrenches to access a bolt, but that is another story. New belt, timed, located, loosen adjuster, crank engine over.
However, the same process was also covered in the engine rebuild section, but it had the small additional step of 'tighten adjuster bolt' before the 'crank engine'.
Needless to say, when cranked with tensioner bolt loose, the belt slipped a few teeth, the interference engine design took out 6 of the 8 valves, and I had to R&R the head and have machine shop work. The belt replacement turned into a whole top end job.
photocopied the appropriate pages and wrote a nice letter to the ford zone rep, which went into a dark hole somewhere.
good little car though.
sometimes I need to rein in my zeal for PM and adopt the 'if it ain't broke....don't break it' mentality.
Fits me to a tee.
What the heck does that mean anyway?
I know what it means. origin golfing?? like a golf ball fits a tee???
1) Put your name on the paper first
2) Check the back of the pages
3) Follow directions
4) Oh, and some stuff about engineering :)
Things I learned in real life:
1) If you need a red pen to edit and get through a poorly translated instruction manual, take it with a grain of salt
2) If you can take it apart without instructions, you can put it back together the same way (paying attention to lubrication, bolt sequences, torque specs, when applicable)
3) If you can upgrade something while you're in there, why not? "If it ain't broke, upgrade it" fits me a little better than "if it ain't broke, don't break it." Not without a few mishaps of course. But who can really show that level of restraint?
1) Read all the instructions.
2) Skim all the questions, marking the ones that you like.
3) Decide which of those you will actually attempt.
4) Work through that set of questions.
5) Re-do all of them.
- Steve
1) read question
2) skip question if it's not easily solvable
3) raise bar for solvability
4) go to step one
First run-through usually skipped all the questions.
It always startled me that there were people wasting 3/4th of the exam on a question they couldn't solve.
NX 7.5
Teamcenter 8
80% of faults are due to maintenance.
It is one reason to move away from predictive routine maintenance to condition based maintenance.
There was the case of a pilot sucked halfway out of the cockpit window after it suddenly fell out. It fell out because, during maintenance they replaced the window and renewed all the fixing screws - with the wrong size screws.
Of course, a timing belt breaking which causes no damage, you wait till it breaks. Usually on some dark moorland road in winter. I had that happen once with a Vauxhall Cavalier.
On the other hand, if it is an Audi A4 if the belt breaks you lose the engine as kcj.
But go to a garage and they won't just replace the timing belt they'll say it makes sense to replace all the belts.
Now since they have to take off all the belts to get at the timing belt, and refit the the old belts anyway, why do I get charged for all the other belts as if each were being replaced individually?
I wish we could go back to the days of real mechanics instead of "Auto Technicians" who solve problems, if they do, by simply replacing stuff until the problem goes away.
JMW
