Suppress drafting object not cooperating with hole callouts?
I am trying to make a hole callout suppress and unsuppress along with the hole it is referencing. I am using "Suppress Drafting Object" with regular dim's and notes and it works fine. I am having fits with a c'bored hole callout created with "feature parameters". If I select all the associated members of the callout I get a warning that says:
"Some objects belong to another controlling expression or feature parameter. Do you want to replace them?"
If I select "yes" the callout immediatly goes dashed.
If I select "no", then suppress the callout and hole (both being controlled by the same suppression expression), everything suppresses except the "THRU" member of the callout and it becomes dashed.
What am I doing wrong?
RE: Suppress drafting object not cooperating with hole callouts?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
