MOV(Motor operated Valve) SIL Certification .
Does MOV(Motor operated Valve) come with SIL Certification . Like SIL-2 or SIL-3 rated MOV to use in safety application.
RE: MOV(Motor operated Valve) SIL Certification .
Most probably not if the manufacturer isn't aware that you require it.
