help for using unistrut to support vertical cable ladders !
Could anyone help me for the solution about how to use Unistrut to support a vertical cable ladder along with a vertcal steel column?
Pictures for the installation would be much better.
Thanks in advance!
RE: help for using unistrut to support vertical cable ladders !
Fasten the unistrut pieces to the column horizontally with beam clamps or by welding. Fasten the ladder tray to the unistrut with tray clips and spring nuts.
Bill
"Why not the best?"
Jimmy Carter
The solution proposed by waross is detailed enough, in my opinion.
If you need a sketch it would be better if you could, at first, give your sketch of the cable ladder and column position.
