Helix Amendment
Helix Amendment
I have drawn using the helix and tube tools a copper coil for heat transfer-see image below.
http://i42 3.photobuc ket.com/al bums/pp315 /skaboy607 /Uni/coilt st_2_2.jpg
What I would like to do is extend the start and end points so that I end up with this-see image below.
http://i 423.photob ucket.com/ albums/pp3 15/skaboy6 07/Uni/coi ltst_2.jpg
All I did to do this was create a datum plane at the start and end points, then draw the lines and apply the tube tool to each individually. When I try and apply the tube tool to all 3 curves, it doesn't like it because either they are not connected or are not 'smooth'?
How can I do this?
http://i42
http://i
How can I do this?
RE: Helix Amendment
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
RE: Helix Amendment
I have attached one part file (NX8) herewith.
Kapil
RE: Helix Amendment
RE: Helix Amendment
I am furnsihing a NX7.5 part file this time.I hope this is a relevant solution.
Kapil
RE: Helix Amendment
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Helix Amendment
RE: Helix Amendment
RE: Helix Amendment
RE: Helix Amendment
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Helix Amendment
RE: Helix Amendment
There are 10 ways to do everything, and 9 of them are perfectly valid.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Helix Amendment
Technically, the glass is always full.
RE: Helix Amendment
Speaking of whichthat's one of the bad things about the history feature: You can find out just which of your coworkers are incompetents.
Sometimes it's just better not to know.
