dear all what advantage doe
dear all
what advantage does multi pad in v5 r8 has over selecting individual profiles in normal pad. Is it only to speed up the padding process when dealing with numerous closed profiles in a single sketch??? or does it has any special features??? in short ...is multi pad inclusion in v5 r8 justified???
truely
amit singh
truely
amit singh
RE: dear all what advantage doe
the multi pad operation in v5r8 is helpful to create pads with different thicknesses in one single command insted of creating in two different operations so it s basically to reduce time for regeneration when u update.
regds
amit kulkarni
