SAP2000v15 run-time error in server 2008
I can't run Sap2000v15 without this error (attached) in server 2008, google search returns no help...
RE: SAP2000v15 run-time error in server 2008
I'm assuming this happens when you try and run your model in SAP and not just when you open the program?  Sometimes, there are errors in your model.  I've found that by going to File - Import and reimporting your s2k file fixes the problem a lot of the time.
If not, I'd consider sending it over to CSI tech support and they can take a look at it and let you know the issue.
