creating multiple spheres on imported coordinates
I have a box filled with (randomly generated) points. On these points i want to create spheres with a constant radius. I can do so by the 'create a sphere' method, but I can't select more than one point. Since I have over a hundred points in my box it is going to be time consuming to add all the spheres seperately. Is there a way to create all these spheres at once from the different points?
RE: creating multiple spheres on imported coordinates
Below is a journal for creating spheres centered on al point objects in the display part.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Module Module1
    Dim s As Session = Session.GetSession()
    Dim ui As UI = UI.GetUI()
    Dim disppart As Part = s.Parts.Display
    Sub Main()
        Dim pnts As PointCollection = disppart.Points
        Dim dia1 As Double = NXInputBox.GetInputNumber("Enter Sphere Diameter")
        For Each pnt As Point In pnts
            createSphere(pnt, dia1)
        Next
    End Sub
    Public Sub createSphere(ByVal pnt As Point, ByVal dia1 As Double)
        Dim nullFeatures_Sphere As Features.Sphere = Nothing
        Dim sphereBuilder1 As Features.SphereBuilder
        sphereBuilder1 = disppart.Features.CreateSphereBuilder(nullFeatures_Sphere)
        sphereBuilder1.CenterPoint = pnt
        sphereBuilder1.Diameter.RightHandSide = dia1.ToString
        Dim nXObject1 As NXObject
        nXObject1 = sphereBuilder1.Commit()
        sphereBuilder1.Destroy()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Hope it helps
Frank Swinkels
I'll give it a try, I'm not really experienced with Unigraphics.
Thanks for the help so far.
Sander
May i ask why you want to create spheres on random points ?
/ Tomas
I want to analyse the mechanical behavior of a polymer matrix filled with filler particles. When the material is created for experiments the fillers will be randomly distributed throughout the matrix. Therefore the spheres have to be randomly distributed in the model as well.
Sander
@FrankSwinkels
your script gives me some errors when I run it. I don't know if there is anything that I should change to make it work with my file.
The errors I get are:
>>Type 'Features.Sphere' is not defined
>>Type 'Features.SphereBuilder' is not defined
>>'CreateSphereBuilder' is not a member of 'NXOpen.Features.FeatureCollection'
I'm running NX5 if that makes any difference for the scripting. The newest version I could install here at the university is NX7.5.
Sander
Yes you need to run this on NX6 or later.  I have tested the journal on NX6 and NX7.5.  I am not sure but the earlier NX may still have the sphere as a non-feaure primative.  If that was so it would error out as you described it.  It may also be that spheres were not supported by journalling in NX5.
Frank Swinkels
Yes, that did the trick. Thank you very much.
One last question though. Doesn't the script work with decimal numbers? My box has dimensions 1x1x1 mm and I want my spheres to be 0.05 mm. However when I enter that into the script the spheres get diameter 5 mm, so it doesn't seem to read the decimal. When I upscale the entire model to 100 mm and insert sphere diameters of 1 to 5 mm it works perfectly.
I tried to change the 'Double' entries to 'Decimal', but that doesn't seem to work. For example an entry of 1.5 for the diameter is seen as 15.
Could be a .net cultureinfo error, try replacing "sphereBuilder1.Diameter.RightHandSide = dia1.ToString" with "sphereBuilder1.Diameter.RightHandSide = dia1.ToString(System.Globalization.CultureInfo.InvariantCulture)"
Unfortunately that doesn't solve the problem.
Okay try this then
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Module Module1
    Dim USculture As system.globalization.CultureInfo = New System.Globalization.CultureInfo("en-US")
    Sub Main()
        Dim dia1 as Double = 0.0
        while dia1 <= 0
             NXInputBox.ParseInputNumber("Input sphere Diameter", "Diameter", 0.05, system.globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentCulture, dia1)
        end while
        Next
    End Sub
        sphereBuilder1.Diameter.RightHandSide = dia1.ToString(USculture)
    End Sub
    End Function
End Module
Yes, that worked. Thank you very much!
Just for my benefit and education when I run my original program/journal and entered 0.05 I obtained the correct spheres.  What were you doing that caused you not to get the spheres?
Frank Swinkels
I don't know. I got spheres, but the diameter was the first non-zero number in the number I entered for the diameter. So 0.1 became 1 and 0.10 became 10. For the rest I didn't change anything, just ran your script.
It has to do with how .net formats numbers for different regions. Usually "." are turned into "," by the toString() method which is not something NX likes. Thus the need for system.globalization class.
