Drawing view naming irritation
When creating section and detail views Solidworks automatically names the view with the next letter in the alphabet after the last view it named. However, if I delete one of the views, Solidworks doesn't "recycle" that name, so every time I create a view from then on I have to manually rename it if I don't want a gap in the letters. This is kind of irritating. Does this bother anyone else?
RE: Drawing view naming irritation
You can adjust this in the sheet properties, under "Next view label".
Excellent, thanks! That sure was an easy fix.
It's 'after the fact' I think, but you can click the button 'Manual View Label' - and name it whatever you want.
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz   11.9 GB of RAM
