loading of transformers
hello
i have a case that i work on transformer its rated =500kva,loaded with 400kva,(i.e loading is 80%). i have backup transformer rated 250kva,what is the optimum loading for both transformers?
RE: loading of transformers
thanks a lot for your reply
If you are talking about putting the two transformers in parallel, that is another matter and probably not a good idea.
Possibly your 80% loaded transformer is still below maximum efficiency loading.
