Transform Question
Transform Question
I looked though previous questions regarding transform in 7.5 but did not see what I was looking for. In NX5, I could transform (move the position of a solid body) for example 1.00 inches by choosing the vector and setting the distance and finish by clicking "ok". If I knew I wanted to move it 2 or 3 times I would click apply and not have to reselect the object. With the move command in NX7.5 I have to reselect the object when I click apply, is there a work around?
RE: Transform Question
Edit -> Move Object...
...command, correct?
After selecting the object(s) to be moved, select the 'Dynamic' Motion option in the Transform section of the dialog and when the XYZ Translate/Rotate 'Handle' is displayed select the desired Translate or Rotate axis. Once selected, an on-screen Distance/Angle widget will appear. Enter your desired incremental Distance/Angle and hit 'Enter' on the keyboard as many times as desired. At any time, you can switch to another Translate or Rotate axes and continue by entering a new incremental value and hitting the 'Enter' key. If you wish to define an arbitrary Axis, whenever one of the Translate handles is selected the Vector icon is active in the Transform section of the dialog so that you can orient the direction of the handle however you wish using the tranditional Vector options. Again, once oriented in the desired direction, you can once again hit the 'Enter' key to incrementally move the selected object. However, please keep in mind that in order to accept the final position of the object, you will need to select either the OK or the Apply button which will complete the Move Object operation.
Anyway, I hope this was what you were looking for.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
clicking the vector arrow inserting the value and enter several times.
http://www.eng-tips.com/viewthread.cfm?qid=295037
John R. Baker, P.E.
Industry Sector
Cypress, CA
