how to zoom back after panning?
Hey,
Im using autocad lt and 2000, the other day when i was using autocad 14 at a different station, i noticed that when you had panned, and than wanted to 'zoom back', the zoom would go back to the start position before the pan.
In the Lt version which i am using the when u pan and then 'zoom back', it would move only about an inch and not back to the original position before the pan.
How do i tweek LT and 2000 so that it zooms nack to the orriginal position even after panning?
Daniel
Daniel
RE: how to zoom back after panning?
As I have seen, there's no workaround on Autocad 14 for the problem you stated. Nevertheless, what you can do, despite of comfort of using dynamic zooms and pans is naming views and restoring them.
Hope this helps,
Robert.
