How to Dimension Divots?
I'm having a disconnect today.  Image you have a plate with a series of spherical divots (like little bowls) in a pattern.  Would I dimension those using SR for spherical radius, or would I dimension them as a Diameter with Depth and Full Round?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: How to Dimension Divots?
How important is the exact depth of the SR? The best way is to ask the QC inspector how they are going to inspect it. It might be easier to inspect the true/actual diameter of the SR divot than to find the depth of a SR.
Our QC will use a laser scanner, so I'm not sure it matters too much Koda94.  Depth is fairly critical due to it being a optical feature.
Jim, I've never seen SD, only SR.  I'll have to look into the use of SD.
Sorry if this is obvious, but just so you know, it's written SØ  (not SD).  That's what Jim meant, but it's tricky to get that symbol here in a textual post.
But for your situation I'd use SR, since they're only partial spheres.
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
It sounds like the features need to be controlled more precisely than just their radius of curvature and possibly a depth from some implied location and orientation, so profile of a surface relative to the surface from which they should be located (either the one they're cut into or an opposing surface) seems like the best approach.
Dean
www.d3w-engineering.com
Jim, I've never seen "SD" in Y14.5.  Is that a standard alternate practice?
John-Paul Belanger
I have seen it used, though not in standards.  But I was saying that either SØ or SR, not SD (as you indicated, that's just a typing shortcut rather than hunting down the diameter symbol.
Jim Sykes, P.Eng, GDTP-S
Profile Services  www.profileservices.ca
TecEase, Inc.  www.tec-ease.com
