Minature Slew Ring/Turntable Bearing???
I'm looking for a minature internal tooth slew ring. I say minature because everything I've found so far is HUGE. What I'm looking for should be roughly 6" OD x 4.5" ID and very thin (not more than 1/2"). I did find one at Kaydon but it turns out that although it's in their catalog, they've never actually built one and minimun required is way beyond what I need (or can afford on this project).
Here's a link to the Kaydon bearing I'm looking at. Maybe it can help any one of you understand what I'm trying to say: h ttp://data sheets.glo balspec.co m/ds/50/KA YDONCorpor ationBeari ngs/02C126 EF-3E67-47 5C-8786-3F 360BFED410
I sure would appriciate any help... Thanks in advance.
RE: Minature Slew Ring/Turntable Bearing???
Add your own mounting rings and gears, press fitted or bonded or mechanically captured.
Mike Halloran
Pembroke Pines, FL, USA
