Catia hides point when rotating view
Hi all,
Where would an option to turn off the points, turning hiden during rotation of a view?
Jim
RE: Catia hides point when rotating view
No, there is no option for that.
In options,display, there is an option for the Z buffer. Not sure of the actual verbiage, but this will get you close. I will look tomorrow and give you the actual.
TOOLS/OPTIONS/PREFORMANCE/PIXEL CULLING/WHILE MOVING/ Changed from 3 to 0
Jim K
If memory serves, the magic number for the "pixel culling while moving" setting is 2.
For understanding, the pixel culling setting is a way to reduce the level of detail displayed. It's become a very useful tool for me, when I have to deal with very large assemblies. I have to set it to 10 or higher in order to be able to do much of anything.
Same behavior with the level of detail settings: larger number means more coarse, smaller number means more fine. Hope that helps with the general understanding!
Cheers
