Edrawing rendering ".dwg" wrong
When viewing a ".dwg' drawing from the vault using Document Information some, but not all, of the dimensions are moved off of the part being dimensioned.
The original file was edited in 2D Editor and checked in fine. It also comes out of the vault and is correct. It's only when viewed with Document Information and/or the Edrawing viewer that it is messed up.
Has anyone else ever ran into this problem before?
Nvidia Quatro FX 1400
8.0 GB RAM
AMD Phenom 9850 Quad core @ 2.50Ghz
SW2010 SP4.0
Win 7 64bit
RE: Edrawing rendering ".dwg" wrong
Is perspective or exploded view involved?
Are section views or detail views involved?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
The drawing is literally a flat 2D, no views and not in any way connected to a model. There are sections and detail views, but they were created by copy and scale type methods(old school AutoCAD style).
Also, there are several other drawings in the vault with the same format and such, but they don't have this problem?
8.0 GB RAM
SW2010 SP4.0
Win 7 64bit
