Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's fun to see others going through the same stuff I did and be able to help. It's also a way for me to stay sharp and not lose the stuff I've learned..."
Geography
rb1957 (Aerospace)
26 Jan 12 11:51
http://www.smh.com.au/world/engineer-debunks-theory-of-flight-20120126-1qjrc.html
i was hoping for something more radical ... he's going back to the old myht that two molecules of air ahead of the wing join up again after the wing, the longer distance of the path over the wing measn it has to travel faster, ...
no, he says it's the shape of the wing causing lower pressure above ...
which from bernoulli means higher speed ...
IRstuff (Aerospace)
26 Jan 12 12:06
Let's not bring THAT subject up again.  It was beaten to death a couple of years ago here, when someone brought up the question of circulation.  Moreover, the "professor" is promulgating a myth to "debunk" the other myth.  His "explanation" uses pressure differential to "cause" lift, which, we know, is not correct either.  If he had gone on to conservation of momentum, I might have gotten interested.
TTFN
KENAT (Mechanical)
26 Jan 12 12:40
If the curve is do damn important then why does a flat plate generate lift quit nicely if put at an appropriate angle to the airflow.  Urggh.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
KENAT (Mechanical)
26 Jan 12 14:50
Hang on, is this the clip http://www.youtube.com/watch?feature=player_embedded&v=UqBmdZ-BNig
In the clip all he does is demonstrate that particles going over the top of the wing don't arrive at the back of the wing at the same time as those going under.
However, in the article the talk about curved 'wing' does not match what I was taught, or experiments we got to conduct.
GregLocock (Automotive)
26 Jan 12 16:31
It is only the Sydney Morning Herald, which outsources its journalism and editing and printing. Some of the comments underneath are pretty funny (No my pen-name isn't John Shaw from Melbourne)
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
KENAT (Mechanical)
26 Jan 12 16:55
Well yeah, I was only going by the part in quotation marks, which I vaguely hoped was at least from the prof.  Now it may be out of context but unless they really changed the wording or made it up then it doesn't look good.
FeX32 (Mechanical)
12 Feb 12 11:43
I also was taught the "faster top - slower bottom" theory in uni.
I also vaguely remember one of the profs mention that the lift may have to do with the coefficient of drag at certain angles of attack. The higher the drag the more momentum is displaced. Then the lift can be derived from there, possibly.
peace
Fe (IronX32)
rb1957 (Aerospace)
13 Feb 12 6:37
that's cause it is "faster on top", 'cause the static pressure is lower.  the problem with the two molecules meeting up again is that i think it is a simplification for the masses.
KENAT (Mechanical)
13 Feb 12 21:03
Pretty sure faster on top, slower on bottom is more than a theory, heck that video certainly suggests it.
It's the 'why' that still leads to debate.
IRstuff (Aerospace)
13 Feb 12 23:25
The faster implies a lower pressure, so it boils down to whether the pressure differential is enough to lift the plane.  If it isn't, then that theory is wrong.
TTFN
KENAT (Mechanical)
14 Feb 12 22:09
Well, I was taking for example the demonstration of the pulsed smoke plumes - where that over the top clearly reached the rear of the wing before that going under the wing - as a reasonable indication that the air over the top is effectively traveling faster than that under.
So hence I'm pretty confident in the 'theory' that air over a lifting wing is traveling faster than that under it.
This was in response to FeX32's comment.
I wasn't getting as far as applying Bernoulli, and definitely wasn't straying into conservations of momentum or bound vortex territory etc.
berkshire (Aeronautics)
14 Feb 12 22:34
Hell Yawll aint getting it, yonly get lift if th wing deflects air down equal to the weight of the plane an it don matter how it does that.thumbsup
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
btrueblood (Mechanical)
15 Feb 12 9:51
Horses, dead, beating.
IRstuff (Aerospace)
15 Feb 12 10:26
Sounds like a mil std:
"Military Standard
Horses, Dead, Beating"
TTFN
FeX32 (Mechanical)
15 Feb 12 11:24
I'm not disagreeing with the theory. I would just feel more comfortable if we could relate it to a differential change in momentum somehow.
Anyways, I don't want to beat any horses to death, what did they ever do to us besides provide us with ample transportation for centuries.
cheers
peace
Fe (IronX32)
rb1957 (Aerospace)
15 Feb 12 11:33
Horses, Dead, For the Beating Of ...
IRstuff (Aerospace)
15 Feb 12 11:46
FeX32 (Mechanical)
15 Feb 12 16:00
glue? lol smile
peace
Fe (IronX32)
KENAT (Mechanical)
15 Feb 12 21:28
... and yummy French cuisine...
FeX32 (Mechanical)
15 Feb 12 23:37
Ok, the glue and French cuisine went right over my head lol
peace
Fe (IronX32)
KENAT (Mechanical)
15 Feb 12 23:44
Well, dead horses have never been much for providing transportation.
At times in the not so distant past they did form the raw material for certain glues (or at least parts of them did).  http://en.wikipedia.org/wiki/Animal_glue
The French also eat Cheval.  http://en.wikipedia.org/wiki/Horse_meat
How short are you FeX32?
FeX32 (Mechanical)
16 Feb 12 11:14
haha. Nice KENAT. Thanks.
I am not a large man. Only large in some ways wink. I am average height I would say. lol
peace
Fe (IronX32)
IRstuff (Aerospace)
16 Feb 12 11:49
He's tall enough to just keep his feet on the ground, to paraphrase Lincolm
TTFN
FeX32 (Mechanical)
16 Feb 12 13:20
Yea, and if I ever start to tip over I always have my third leg to prop me up.
peace
Fe (IronX32)
drawoh (Mechanical)
16 Feb 12 22:02
KENAT,
   The wing in your video looks symmetrical to me.
   If the wing were asymmetric and the angle of attack were zero, I think there would be a higher velocity and lower pressure on top of the wing.  Also, the air coming down from the top would have more energy, causing the air to be vectored downward, which is of course, the other explanation for airplanes flying.
   Beating a dead horse does not cause flight as far as I know.
               JHG
cloa (Petroleum)
17 Feb 12 19:49
Isn't lift something to do with vortices?
Helpful Member!  AeroNucDef (Aerospace)
20 Feb 12 15:11
Babinsky wrote a paper in 2003. It's quite interesting.
http://iopscience.iop.org/0031-9120/38/6/001/pdf/pe3_6_001.pdf
KENAT (Mechanical)
21 Feb 12 17:35
With a cambered aerofoil it's effective angle of attack that comes into play if memory serves.  At an effective angle of attack of 0 there will still be 0 lift as I recall.
Close Box
Join Eng-Tips® Today!
Join Us             Close
