PLC AC Voltage Detector
Using an analogue input card with a plc, i want to know if you can sense the polarity of the AC mains? With a 240V phase to neutral voltage connected through a 15KOhm resitor, the current is limited to 16mA.Can the PLC then use this to determine when the Voltage value is in the positive/negative half cycle?
RE: PLC AC Voltage Detector
Gunnar Englund
www.gke.org
TTFN
I do not know of any COTS PLL modules that can be installed in a PLC rack. Are there any?
Gunnar Englund
www.gke.org
