Sketch dims not visible in assembly when part is changed to work part
Our German division are having problems with working in the context of the assembly when trying to edit sketches.
If they make a part the work part and and then go to edit a sketch, there are only a small number of the total sketch dims visible, infact yesterday as I was looking via an app share, there was only 1 visible dimension. However, if we make the part in question the display part and edit the sketch, then all the dimensions are visible as you would expect.
Any ideas?
Many thanks
Simon.
Any ideas?
Many thanks
Simon.
Best regards
Simon NX7.5.3 - TC 8 www.jcb.com
RE: Sketch dims not visible in assembly when part is changed to work part
If you're doing the latter, the only dimensions which will appear, along with the sketch while in the Feature Edit dialog, are the actual driving dimensions. The auto-dimensions will ONLY be visible when you're actually in an edit sketch mode, either the Sketch Task environment or when using the Direct Sketch tools and the sketch is active.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
We are actually editing the sketch itself in direct mode. It is very strange. I can try and get a screen shot for you.
Best regards
Here is a power point that contains a couple of images of the sketches as described, as you can see, we are editing the sketch directly, and not an extrude feature.
Many thanks
Simon.
Best regards
Also make sure there is no funky "visible in View" settings, even in the model views.
John R. Baker, P.E.
Industry Sector
Cypress, CA
