past api 653 exam papers - notes
hi name brian jacobs from south africa ,have applied for api 653 march 2012 exams, however api653 does not have tuition or classes in south africa, so i have to go it alone do you know of anyone who could give sell or loan past exam papers or notes. i have worked as a (welding & fabrication inspector on tanks)which did not include calculations or the scope of a api 653 inspector (starting to get apprehensive)
RE: past api 653 exam papers - notes
I haven't taken the exam for 653 however, I did take the 510 exam. To prepare, I reviewed the 'body of knowledge', obtained all of the referenced documents and studied hard.
You can do the same for 653, its just work.
You can review many API based test documents here
http://publications.api.org/
Somewhat painful to use, but at least you can review the documents.  All you need to do is register...but you cant print or save them.
