Rebar Field Fix : 2-#5 instead of 1-#6
A contractor on a project of mine accidentally installed a grid of #5 bars in a foundation when he should have used #6's. So, as a field fix, he just added an extra #5 bar at each bar he had already laid down. He's getting me pictures tomorrow, but I'm assuming 2-#5 bars sitting right next to each other acting as a single bar. Does anybody see a problem with this? I've thought about it and feel like it is acceptable. Sure, if the bars are right next to each other, they both won't be 100% encased in concrete but will be pretty close. I also don't think they need to have any space in between to allow for aggregate to flow through since they're intended to act as one bar. Also, I feel good that the ductility of steel will allow the bars to yield and share the load with each, therefore acting more like a single bar with an area greater than the #6 that was originally specified. Thoughts?
RE: Rebar Field Fix : 2-#5 instead of 1-#6
Or, just add more #5's in between what is there....if there is enough space and check that design
Probably OK but check it. And remember, the loads we use are usually fairly conservative -- if you are within 10% - probably OK
And CHARGE the contractor. Maybe he will pay closer attention next time.
Like the old saying "It is easier to ask forgiveness then seek permission"
As for checking it I don't feel like I need to look at my model as long as I can use the full area of 2-#5 bars to replace the #6 bar. If people think I can't use the full 100% area of the 2-#5 bars then I would need to be able to use at least 70% of the .62 in2. area to keep it within the area of a #6.
And when you say to charge him are you referring the investigative time I have spent on this so far because I will do that. I don't deal with billing, but I'll write it on my time card and my boss will decide what to do with it.
Unfortunate about the forgiveness/permission saying. While it may be easier for him I'd rather these things get addressed before the concrete sets.
Bundled or spaced 2" apart. ACI 318 7.6.6 is intended for more serious conditions.
This is concrete foundation work.
Even if "bundled" how did he actually tie them together: with wraps every 12 inches - or 24 inches, or 36 inches, or just at the ends? At every intersection with the other lattice bars?
Get your money back. And get a way so HIS insurance pays the structural warrantee when it breaks under load.
