Can't separate revision symbols from a drawing view
I've been revising lots of drawings and the revision symbols that move when drawing views move are driving me nuts. Is there some way to break them away?
RE: Can't separate revision symbols from a drawing view
Delete/cut from view, dbl-click on sheet outside of views, add/paste.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
You can change the view that the symbols are associated with by adding an arrow, pointing it to something in the view and then switching to no arrow (works for notes as well)
Thanks Chris, I used the cut-and-paste technique. Now it's all behaving as it ought to.
Fig
Wow, I completely misread that, I just found out that trick and was anxious to share!
