How to specify nitriding of gears & DIN equivalents
How do you call out the nitriding on a gear drawing? Is it sufficient to list a standard? Do you give a case depth?
Also, I'm working on this project with a German counterpart. Since gears are his specialty, not mine, he gave me a DIN 867 Quality 8 standard. What is a US equivalent?
RE: How to specify nitriding of gears & DIN equivalents
The depth is usually defined as to the hardness which equals 110% of the core. Liase with your heat treater for best times and expected depths for materials.
Because of the shallow case this is not suitable for large or heavily loaded teeth.
On the drawing you need only stipulate the material treatment and the case depth. Annealing or stress relieving
after roughing out will help keep distortion to a minimum.
You will not be able to machine afterwards (except grind) but you can mask off areas to be left soft.
As a rule of thumb AGMA 8 and DIN 8 are about the same then one goes up and the other down from there. ie AMGA 9 = DIN 7 etc. But it is only a rough guide as there are so many catergories to take into account.
see my site for additional info that may help http://uk.geocities.com/mikebull2001/green.html
