I need a basket strainer - 40 microns at 500F
Does anyone have experience with in-line filtering of hot oil. I am looking for a basket strainer to put in the flow to trap contaminants. This is a positive displacement pumping system that flows 25 gpm at 475F. Fluid capacity is about 25 gallons. Viscosity of the oil is about 0.85 of water.
RE: I need a basket strainer - 40 microns at 500F
Yes, I can put you in touch with a vendor that services the oil and gas industry.  Your application is very standard.
Try Mueller
Try Tim Randall at Jamison Products see www.jamisonproducts.com
good luck
