Hardware rendering issue
Hi, I have been having problems with PATRAN 2008 freezing within only a few minutes of opening the programme. It appears that the only way to resolve the problem is to uncheck the "hardware rendering" box within the 'preferences - graphics' menu. I have had my hard drive cleaned up, disk defragmented, and my graphics card changed and this hasn't solved the problem. I use CATIA V5 on the same PC with no problems. Any ideas as to what the problem could be?
RE: Hardware rendering issue
In my experience all my issues with systems mysteriously resetting or freezing were the result of a PSU unit on its last leg or merely acting up.
Good luck.
Lisa
if you need to purchase one then i suggest maybe getting a higher watt rating one.
Cheers
Lisa
