none conductive coating
Hi Guys
I am looking for a none conductive thin (.002-.004 max) coating, to apply to an alum alloy with nickel plate. Is conformal coating suitable?
Later on I have to bond a device to the none conductive surface.
I you have any suggestion I appreciate
RE: none conductive coating
"The attempt and not the deed confounds us."
There are many different types of organic coatings that are non-conductive, and would provide an excellent base for subsequent adhesion. I would pick something similar to the adhesive you will be using, for example, if the adhesive is epoxy, then coat the nickel plating with an epoxy prior to the final bonding step.
