Photoelectric Displacement Sensor Manufacturer
Hi all,
I am seeking an inexpensive photoelectric displacement sensor. The requirements of the sensor are that it senses over a 10mm range (preferably 0-10mm, but could be greater like 30-40mm), and is accurate to .1mm.
The application is to detect the distance of a rubber tube that will expand and contract due to a pulsatile pressure load. Please let me know if you need any more info.
RE: Photoelectric Displacement Sensor Manufacturer
I think what you are seeking is expensive. "Photoelectric Sensors" are cheap. "Displacement sensors" are expensive. Typically displacement sensors use lasers in a retroreflective configuration. The bounced laser beam is sensed on a chip of some sort. A corresponding analog voltage calibrated to a distance is output. Never mind the user interface, documentation, & controller that goes into all of that. It all costs a lot of money.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
TygerDawg
Blue Technik LLC
www.bluetechnik.com
