Auto- transformers phasing
My background, I'm a superintendent for a REC in NW Oklahoma. We recently built a new 3 Ø line, 1/0 acsr. This is for a 2 way feed between the Fargo substation and the Gate substation. It would not phase in, 30 degrees angular displacement. Ø to Ø voltage is North Ø to North Ø 7200 volts, North to Center Ø 15,100, North to South Ø 7800 volts. The other phases were about the same. My question is where is the 15,100 volts coming from. This is a 12.4/7.2 line. Thank you, Bob
RE: Auto- transformers phasing
You'll need to roll phases on both sides of the transformer feeding the new line to get it to phase.
