Thin Ice
Thin Ice
My parents have always drilled it in my head that ice has to be at least 6" thick before I could go skate...which was hard sometimes as a young child because I could see the older (and less supervised) kids out playing hockey on the thin ice.
I'm sure 6" is the safe number, and I'm not about to go jump around on 3" of ice...but this got me thinking..how would you go about figuring out on paper how thick the ice had to be?
I did some looking around on the internet and found a range of values for the tensile strength of ice...in the range of 1 - 3 MPa.
Any suggestions on how to do this...besides throwing the whole problem into some FEM software?
RE: Thin Ice
Dik
RE: Thin Ice
RE: Thin Ice
I would imagine this would be no different than designing a raft foundation with ice substituted for concrete and water substituted for the soil below.
RE: Thin Ice
Point Force = 400 lbs
From here, figure out the deflected shape (2-way action) and equate the volume displaced vs stiffness and varying thicknesses of ice. Not only is the ice buoyant but as the ice deflects down it displaces the water caulsing a resultant buoyant force up (minus the weight of the ice and skater).
Check stresses against bending and check 2-way shear. The biggest problem with ice is that it is brittle so no redistribution of loads after failure. Should probably have a safety factor of 4 or more.
RE: Thin Ice
Fresh ice is usually somewhat consistent and has few cracks or displacement areas, but as the season goes on more cracks and weak points occur, but not enough to disrupt skating activities but can support heavier loads.
The ice behaves like a beam on an elastic foundation once there are a few cracks that always occur as it goes through the season.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
RE: Thin Ice
RE: Thin Ice
There is likely an obscure textbook somewhere with the data you seek. Also, the ice roads they use for trucking would be a source of information.
RE: Thin Ice
As far as the minimums, last week I saw a situation where an ice fisherman had an ice house/tent on a sled sitting on 4-6" of ice - new, pure, unfractured ice and you could see and identify the fish under the ice before it was pulled out or cut off. Once the ice expands and fractures, the load carrying capacity becomes variable. But, still generally depends on the general ice thickness since that eventually becomes the localized capacity unless you have an "ice road hauler".
Dick
RE: Thin Ice
Watch IRT - Ice Road Truckers - those guys are nuts!!
RE: Thin Ice
RE: Thin Ice
Concretemasonry and SteelPE, you are both saying to look at the water as an elastic foundation...if you were to take that approach how would you determine the stiffness of the water? Would it just be the buoyancy?
RE: Thin Ice
RE: Thin Ice
RE: Thin Ice
The army corps reference was excellent...exactly what I was looking for. Thanks again!
RE: Thin Ice
The buoyant force you mention I would assume is local,however there also seems to be a confinement mechanism in the body of water occuring at the same time. As the ice deflects locally it displaces a certain vol of water which in turn tries to displace surrounding ice upwards...the ice acts or tries to act to contain the vol of water...very complicated to get a handle on..
CANEIT..I don't have that army corp manual and would be interested in a synopsis of the solution you discovered...thanks
RE: Thin Ice
http://1
chapter 8 relates to this discussion...but I've read through a couple of other chapters as well and it is all very interesting.
RE: Thin Ice
We always talked in terms of about 4" of ice for safe walking or skating. But I've walked on much thinner ice with some trepidation, in not too deep a water situation. You can feel and see it flexing just before you fill your boots with water. This is very dangerous where there is any moving water since it can keep the ice from forming despite cold weather, it melts it from below. Rivers or streams are an example of this all season long. You must know the lake, because a lake bottom spring entering the lake, 20' below the ice will stir the water enough to keep the ice very thin. With no guarantees, we thought: about 5" of ice for snowmobiles and ATVs; about 8" for compact cars; about 12" for light trucks, spacing of these heavier loads are at your own risk.
Snow acts as an insulator, so if you get ice and then snow too quickly, the ice will not develop thickness very quickly. The weight of the snow may actually depress the thin ice, slowly, with water coming up through cracks or weak ice and forming an inferior (not strong) ice/snow mix. Some compressive strength once it freezes, but no tensile strength. For ice roads, as quickly as you can get a light plow on the ice, you want to plow the ice road very wide, so the ice will continue to form a nice wide, and thick, roadway.
There is a buoyant force (the elastic found.), force/stress transfer through the ice and away from the point load area as Teguci suggests, and there is a confinement/pressure mechanism going on as the ice deflects under load as Sail3 suggests. This shows up in the form of water geysers or artesian like water, flowing up through cracks in the ice in the vicinity of a heavy load like a car. This must be in the form of a ice stress/deflection and buoyancy/pressure wave moving along under the moving load. And, you can see the two sheets of ice displace w.r.t. each other as the wheel goes over a fresh crack. I have had ice crack right under my feet, suffice-it-to-say I was glad I relieved myself before I left the house. I have had ice cracking behind me, with water welling up through the cracks, using a snowmobile. If you keep moving, you can stay ahead of it and get off the ice. I'm sure that if I had stopped I would have been fishing the snowmobile out of the lake. This happened during an age where I thought I was more invincible than I know I am now.
RE: Thin Ice
Is that where the term "spud bar" came from?
RE: Thin Ice
Ice is a very flexible medium that can be amazingly strong and resilient. I can remember numerous times when you could hear the ice crack (for hours earlier) and shift as you were ice fishing out of the front door of your car. You just moved to give the cracks to heal and freeze and come back a day or so later because it is not permanent. The more permanent deformations are the ice ridges where they usually place bridges over the problems even when there is 4' of ice or more.
Ice is not a static condition. I spent many days of spring ice fishing on 6" of "soft/melting" ice where we were on skis and pulled a canoe in case there was a shift. - It is not a scienticif subject.
RE: Thin Ice
RE: Thin Ice
The prime example is Lake Mille Lacs is MN that is generally circular (20 miles across)and is very heavily used in the winter. On week-ends and the population can be over 10,000 for the week-end (Fri PM to Mon AM) with many people spending the full time. Many of the houses are towed out in the early winter by dozers or tractors and require 12' wide roads over where the ice happens to be. Before the ice goes out, many are slid off the lake and placed on foundation to serve as summer homes on the shores. - The homes/ice houses generally have generators, satellite dishes, TVs, refrigerators, freezers, furnaces and several rooms. I have heard there are a few 2 story ones.
There is little engineering or science in the timing, so the owners "feel" their way out by drilling holes out and fish to the desired placement and use portable shelters as they explore and go. The ultimate decision on the loads on the ice resides with the resort owners moving the loads out because of the value of the equipment used. The resort owners generally maintain and move the bridges over the ridges as they change. They are governed by the conditions as they see them and analyze then by the mile or yard.
The speeds for the heavy house loads are low (unlike the ice road haulers), but the cars and SUVs usually go at 55 maximum. The ice roads on TV usually are not traversed at high speeds and the speed is decreased when they get near shore to decrease the lateral thrust of the waves in the ice. Everything is moving and floating.
It is a unique situation and not controlled by engineers or programs, but it has worked for decades since it is flexible according to the day-by-day conditions.
Dick
RE: Thin Ice
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
