PTO driven whinch
PTO driven whinch
i would like to install a PTO driven winch on my automatic F-350, the question that comes to mind is; do i need to install a manual tranny? the transfer case does not have PTO installed on it at the moment but can i get the PTO attachment and take the plate off the t-case and insatll it or will i need a different t-case. any advice is appreciated
p.s. it is a 1994
p.s. it is a 1994
RE: PTO driven whinch
Pancholin.
PS The PTO takeoff cover on my transfer case doesn't leak either.
Driving the PTO on the transfer case gives you all the tranmission forward and reverse speeds, but the TC stays in neutral, so you must use the brakes to hold the vehicle. Assuming you are extracting someone else. :)
