NX non linear material FEM/Sim Problem
thread825-202613: NX Nastran Contact analysis
I used the above thread as initial information because I am doing a non linear material FEM.
Currently we are investigating the ability to model organics and thus are using Ogden and Mooney-Rivlin Materials.
My problem is exactly the same as the one referenced above. I can apply a Fixed Constraint to one face of a 2x2x2 inch cube. The cube is meshed using Tet(10) elements and therefore is a 3D solid body. I apply a pressure to the opposite face and get the error as follows.
"NASTRAN Msg: ***WARNING: No element connection for node 1 directions 4, 5, 6
***WARNING: Similar warning suppressed for 313 other nodes.
NASTRAN Msg: ***WARNING: Nodal degrees of freedom without element
connection have been fixed for data input file.
This is a very confusing error message to me. When I mesh the box as a solid body, how are the elements not connected in some way ? The simulation will work if I apply two Enforced Displacement Constraints(the only displacements are in the X and -X directions with all others zero'ed) to the opposite faces but gives me an error when i attempt to Fix on face and load the other.
Any help is appreciated !
RE: NX non linear material FEM/Sim Problem
Make sure to include PARAM,AUTOSPC,YES in the Bulk data section, this way NASTRAN will remove all rotation DOF on solids.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
