hoop stress calculation
I have a question:
When calculating the hoop (cylinder) stress in a pipe you use static equilibrium and equate the stress in the wall to the gauge pressure:
2*T*S*1 where S is the hoop stress, T is the wall thickness, 1 is the unit length and then equate it to the gauge pressure times the area so 2*T*S*1=gauge pressure*D*1 where D is the diameter and 1 is the unit length.
they do the derivation here:
http: //www.goog le.ca/url? sa=t&r ct=j&q =mit%20pre ssure%20ve ssels& source=web &cd=1& amp;ved=0C FYQFjAA&am p;url=http %3A%2F%2Fo cw.mit.edu %2Fcourses %2Fmateria ls-science -and-engin eering%2F3 -11-mechan ics-of-mat erials-fal l-1999%2Fm odules%2Fp v.pdf& ei=3dgeT7O SDaTfiALo7 sXVCw& usg=AFQjCN F0TaEc7tX1 ALYWE5mj-O DIo80u0A&a mp;cad=rja
My question is : why use the projection of the area (D*1) rather than the actual area: D*pi/2. Is it because you're projecting the area in the same direction as the wall stress, to get the component of the pressure in the same direction as the wall stress for the static equilibrium calculation?
Really simple, dumb question, i know, but I'm not a mechanical engineer and it's been a while since I've done this.
thanks
I have a question:
http:
thanks
RE: hoop stress calculation
From "BigInch's Extremely simple theory of everything."
