can you update a tabular note from a parts list?
It may be old school but I want to put a Table on a print but use it as a BOM instead of a "Pats List". There are several parts on this print that we don't have modeled. (Stickers, decals, etc.) The parts list also seems to reorder everything in a way no one here is used to (and change is a big no-no here).
I'd like to just be able to update a tabular list of a selected few components part numbers using the values from a part list but have the part list hidden.
Is this possible?
Thanks All!
Is this possible?
Thanks All!
RE: can you update a tabular note from a parts list?
I tried this. When I double click the value in the parts list, the value it has is <W$=@$PART_NAME>. However, when i input this value in the table, it remains unchanged from the previous vale.
Am I doing something wrong?
Thanks!!!
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
When I do that, it looks like the only attribute I can chose is "CALLOUT".
The parts list gets the correct part number but, I am not seeing it here. At any rate, thank you for your time!!
I'll try and see how that works and if I do make the switch to a parts list, can I out a material column, engineering spec column, and a part name column?
In other words you lock where in the parts list it is, so the item number stays the some.
So what shows up in your parts list columns? Is there a part name?
