NX7.5 - Synchronous Modeling (Label Chamfer)
Does anybody know how to use/edit Label Chamfer, under the Synchronous Modeling tool?
What good could one get from using it?
Can you send an illustration/prt.model?
RE: NX7.5 - Synchronous Modeling (Label Chamfer)
First you have to define those faces as a chamfer using Label Chamfer
Then you can add the linear dimensions (using Synchronous Modeling) to define the chamer.
