Locking Expressions
Locking Expressions
Locking Expressions
Can you lock expressions like you used to be able to do in the older versions of NX?
There used to be a padlock symbol that would prevent the user from accidentally modifying a formula.
RE: Locking Expressions
Would be much welcome...
I did find this post but I don't understand how he got the results he did:
http://www.eng-tips.com/viewthread.cfm?qid=309027
New Postjpetach (Computer)
2 Nov 11 17:48
MPTatECT,
The attached part has one "input" expression, p1, a locked expression "my_locked_exp" that uses the input expression p1 as part of the formula. And it has expression p2 which uses "my_locked_exp as part of its formula.
my_locked_exp is a ug_expression KF child rule with lockRule set to TRUE.
In the Tools ->Expression dialog and in the Part Navigator the "my_locked_exp" is not editable.
The example expression is quite simple but it should meet the requirement for being able to define the expression to be used for a curve by equation where that expression is not directly editable but still can react to other expression edits.
http://files.engineering.com/getfile.aspx?folder=f87479c2-4521-42f4-99d6-45e0db6bebe2&file=NX75_locked_expression.prt
Hope this helps,
Joe
Can someone explain:
"ug_expression KF child rule with lockRule set to TRUE"
Thanks!
Joe used KF to write a new Expression Function which allows for an expression to be locked.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I thought the padlock (available using the 'old' expression dialog) only 'locked' the expression from being used as an interpart expression.
You still see the padlock in files containing interpart expressions.
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
