PIER names can not be replicated on v9.7.2
When i replicate a wall on v9.7.0 the name of replicated wall is also being replicated. But on v.9.7.2 names are not being replicated. I could'nt find the solution. Is there anybody who knows the reason of that?
I'm lokking forward to hearing from you.
Sinceraly.
Sinceraly.
RE: PIER names can not be replicated on v9.7.2
Pier and spandrel naming must be unique for the elements associated with one level of your building. So you can't have two P1 piers on the same level, but you can have a P1 pier and an other P1 pier on different levels.
Does that answer your question?
-Peter
Thanks for your reply but this is not the answer i'm looking for. I know it has to be a unique pier name on a story. When i replicate from story 1 to story 2 and etc., pier name isn't replicated.
Thanks again.
Then i can only inform you that v9.7.3 does not copy pier labels either. Good luck with resolving the issue.. or reassigning pier labels at all storeys..
-Peter
Renaming all my piers for each level is pretty tedious...
