Fenner 3020 1-7/8 and Fenner 4030-3 Taper Locks
I have to install the above taper locks on both the driver and driven gears respectively.
I am not familiar with the machining required to do this and i have to design the two gears to be fitted with these taper locks.
If anyone can help me i would be very grateful. The driven gear will be keyed.
I have the spec of the taper lock but it only gives a minimum hub diameter for various materials for the taper lock in question.
Cheers
Cheers
RE: Fenner 3020 1-7/8 and Fenner 4030-3 Taper Locks
Ted
They sent me the data sheet for all the bush sizes in the range. This might be a silly question but why are there 2 diameters given for each value of parameters 'I' and 'K' in the table attached.
Cheers
Cheers
Greg Locock
Thanks.
PS. It would be even scarier if i didn't bother asking.
Ted
note the holes are flat bottomed for screws/bolts to seat against during installation/removal
