Ansys, heat generation calculation question.
Hello all,
I am trying to transfer heat generation from HF Emag calculation done with HF119 element.
Unfortunately, HF119 does not provide hgen output and it has be calculated -- please let me know if there is an automatic way to do this. So, I obtained E field vector at each node and calculated P_loss with
P_loss = 0.5*E*dielectric_constant*E
Now, I applied P_losss to solid87 using BFE. Here's is my question. Does P_loss need to be multiplied with element volume before being applied as BFE or is P_loss applied as it is ?
Any help would be appreciated.
Cheers,
Kyle
RE: Ansys, heat generation calculation question.
Thanks !!!
