Body Color option in Shaded View in NX 6 Drafting
I have a section view in drafting and I want to show the body color as the shaded color view.  When I change to the shaded view I have the option to specify the color, but where is the option to specify using the body color?  I have several bodies that are different colors and I want to show this in the section.  If you can't do this in the view style options, then is there some other workaround to make this work?
RE: Body Color option in Shaded View in NX 6 Drafting
Thanks, I should have remembered that.
