Help to get catproduct user defined properties
Hi cklong,
amazing aplication you have done!
I need to get the user defined properties as you are doing with your code. I've tried a lot of ways but non have work for me.
Could you please help me with this? which function or method are you using??
Thanks in advance!!
RE: Help to get catproduct user defined properties
Public TEA(500) As String
Public TEB(500) As String
Set opart = CATIA.ActiveDocument
Set PartDoc = CATIA.ActiveDocument.GetItem(opart.Name)
Set partnum = PartDoc
PNUM = partnum.PartNumber
descr = partnum.DescriptionRef
On Error Resume Next
Dim XTemp As Long
Dim TE As String
XTemp = 1
A1 = Len(partnum.Name) + 12
While parameters1.Count > (XTemp - 1)
strtemp = parameters1.Item(XTemp).Name
A2 = Len(strtemp)
Set strParam1 = parameters1.GetItem(strtemp)
strtemp = Right(strtemp, A2 - A1)
strt = strParam1.Value
TENUM = XTemp
TEA(XTemp) = strtemp
TEB(XTemp) = strt
XTemp = XTemp + 1
Wend
'this will get the properties name as TEA(1),TEA(2),...
'and the Value as TEB(1),TEB(2),...
i think this is what you need hope this helps you
