Pressure Warnings & HR 235 Material for API 650 Tank
Dear Members,
I am working on an inquiry of API 650, 15,000 bbls Crude Oil Tank. The design data is under;
Design Pressure: 1 psig, Vacuum Pressure: 0.5 psig, Design Temperature: 200 °F, Sp.Gr: 0.7, Roof Type: Conical Supported
I have Etank software. Firstly I worked on 54.1 ft diameter & 37.72 ft height. But because of (1) greater value of design vacuum from max. allowable working vacuum pressure and (2) greater value of design pressure from max. allowable working pressure I changed the sizes & used 49 ft diameter & 46 ft height. The (1) warning was cleared because of change in diameter but the (2) was still active. To control on (2) warning, I used the heavy crub angle (Top Course Stiffener) 8" x 8" x 32 mm thk. The top shell course thk. is 6 mm and the thk. of curb angle is 32 mm.
My question is that " I choosed the correct method to get control on these problems or not?" and if someone have a better way to delete this warning then please share/guide me.
Secondly, Is HR 235 material is equivalent to A-36 or A 283 Gr. C material. If not then guide me how to put & from where the values of HR-235 material. (attached)
Thanks & Regards,
Nasir Khan
Thanks & Regards,
Nasir Khan
RE: Pressure Warnings & HR 235 Material for API 650 Tank
Yes JStephen, I am also agreed with you. But I have no proper reference of any code/ standard to guide client.
Please also guide me on my question regarding attachment of heavy crub angle with top shell course and HR 235 material.
Check the requirements of API-650 in regards to a "National Standard" in 4.2.6, which I think will cover your material. You may also be able to get dual-certified material if that simplifies things.
Thanks JStephen.
Let me clear one thing, is that we already quoted for this project. In initially design we did not used vacuum pressure in our calculations by mistake. Now I am tried to balance the new design (With Design Vacuum Pressure) with the design we quoted. To reduce the shell courses thicknesses I used shell stiffeners.
I am doing tank designing on Etank software. As you advised to use flat plate, I did not find flat plate option in Top Stiffener in Etank. Clear it to me that if I go for 8" x 8" x 1.25" thk. angle which will be weld as a top stiffener with top shell course 6 mm thk, it will fine on not. 8" x 8" x 1.25" angle is easily available from Pakistan local market.
I agree with your comments.....but
What, in your experience, would be a reasonable design pressure and design vacuum for a crude storage tank of this size ?
Do you have any references to guide us ?
I believe that about +10 IWC and -5 IWC would be about right.
A lot would depend on the nature of the crude and the tank location.
Anyone ??????
With the angle, the problem isn't just buying the material but also getting it rolled to the radius.
MJ- a typical US installation would be an atmospheric tank with internal floater- if pressurized, it could vary, but usually wouldn't be that high.
