Steel Sheet Piling Grade
The material that my state's spec book refers to for permanent steel sheet piling is AASHTO M202.
I can't seem to find this spec. without having to pay to download it. Does anyone know if this refers to a particular grade of steel? Also, I assume this is a corrosion resistant steel, although does this spec. include any particular coating?
Thanks for any help.
RE: Steel Sheet Piling Grade
It's a carbon steel. There is A690 marine grade sheeting.
Coating is something you have to discuss with the supplier.
