Cryogenic Level Measurement
Hoping Someone can point me in the right direction. I have two vessels - 70' by 16' filled with Liquid Hydrogen at -423 at 100psig using Nitrogen to offload so there is a regular hard boiling issue. I need a level measurement system to send a signal - no local indication needed.
Fully flexible regarding tank connections and etc. so I'm open to any suggestions - Mainly up against the temp and interface - has anyone dealt with this before?
Thanks.
RE: Cryogenic Level Measurement
How accurate - gross liquid height or for custody transfer?  Can you use a temperature strip on the outside of the tank shell?
Will radar work?
I worked 5 five years ago, in an ASU plant (air separation unit). We had several cryogenic storage tanks (LOX, LIN and liquid argon), level were measured with a level transmitter.
You can find many fabricators (Fisher, Rosemount, etc). Level transmitter works with differential pressure, it takes gaseous phase from nitrogen and internally convert in a signal of 4-30mA, signal goes to a control room or remote panel.
I am sorry shall be 4-20mA
