Print preview not same as actual plot
Hello;
We have installed AutoCAD 2002 and 2002LT on several of our machines. We are having trouble getting drawings to print or plot correctly. We are printing to eithet an HP Laserjet 5SiMX or an HP Laserjet 8100DN.
We routinely do a print preview to check that the drawing will print correctly. However often it will not print correctly even though the print preview is correct. I might add in many cases this is because of a portrait/landscape orientation. It seems that unless you cycle the protrait/landscape toggle several times the print/print preview will not synchronize.
Has anyone else had this problem. It is fustrating many of our drafting people.
