Elevator Cube
Elevator Cube
anybody knows how to design a elevator cube, the load, all the considerations that we have to take at the momento to design the an elevator cube, thanks you
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Elevator Cube
RE: Elevator Cube
Could this possible be an open (3 sided) elevator system that does not stop (hop on and hop off quickly) at a floor and is just a platform on a continuous mechanical system?
If it is a system that that stops between the floors and every other stop (2.5, 4.5, etc. stops), so that usually requires a larger size car.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
RE: Elevator Cube
daniel
RE: Elevator Cube
RE: Elevator Cube
Then I recommend going to 3 or so elevator providers and get their drawings for that type of elevator: Kone, Thyssen Krupp, Otis, etc...
The loads are provided on the elevator drawings. They will include vertical elevator loads (on the rope or hydraulic cylinder), compression cylinder impact at the bottom, lateral rail loads and vertical rail loads.
Things to watch for are the hoist beam, sills to the elevator at each floor and blockouts for buttons and signs.
RE: Elevator Cube
RE: Elevator Cube
RE: Elevator Cube
