Importing from a program (Excel) to AutoCAD
What options are there to import a set of data into autoCAD either as a dxf or have autocad draw it.
Basically I would like to have a graph that was created in excel be a polyline in autocad but thats not all. I would also like a grid to be drawn as well. I know that I can write scipts for the graph poly lines and probably for the grid as well but are there other ways?
How do programs that export there 'drawing' or 'data set' to excel operate? How are they communicating with AutoCAD?
This may be a pretty involved topic so maybe a reference would be most helpful. I know almost nothing about LISP's would it be help to start here or maybe there is a way to use VB/Macro's in excel?
Thanks!
Thanks!
EIT
RE: Importing from a program (Excel) to AutoCAD
Try using the "file insert" function if supported in AC
Enjoy...
I'm not sure how I can you use the file insert or input commands. I mean you can insert different files but I'm not sure how to create those files. Also I'm not trying to show the actually sheet. I am basically drawing an object (like a graph) with excel functions and wanting the result to be drawn in autocad.
Cherrypicker - thanks this may prove to be a solution.
I am still curious though how do other programs communicate their outputs with AutoCAD? Usually I see they are imported as .DXF files.
EIT
Ideally I would like to be able to define the line types, color, even add text or a leader line. Now I'm guessing I wouldn't be able to do all that in excel but do you know of a different program or how I could use to create such a program? I guess this is almost getting into software creation.
EIT
Any suggestions on where to start with this, any references?
Basically I have a series of data points that are the result of excel equations. I need to take this information and get it to excel. I'm just struggling on how to put this all together.
EIT
I will volunteer a little caution about the effort. Autodesk's supporting information for DXF makes some sly digs at competitive products, stating that a program that must read DXF files as input should be flexible about the order and format in which DXF elements are presented, because according to the documentation, there should be several legitimate ways to organize the information in a DXF file.
Ironically enough, AutoCAD itself is one of the more fussy readers. It is possible to generate DXF files that other CAD programs can read without error, and which AutoCAD will barf upon.
So the most logical way to proceed is to generate a nearly-null DWG file in AutoCAD, e.g. something with just one line, export it from AutoCAD as a DXF, and then use that as a template for what Excel must generate. In particular, you can capture and 'can' the required preamble and postamble generated by AutoCAD, and set up Excel to spit those out from fixed files, or to generate preamble and postable in exactly that format, and to interpose the geometry you wish to export in the documented way.
Good luck and have fun.
Mike Halloran
Pembroke Pines, FL, USA
I'm still debating whether to write a fairly involved script or try and generate a dxf file. I believe in the long learning the how to generate a dxf file will be more useful.
Just a little background on where this stems from - there are a couple different segmental block retaining wall manufactures that have software which allows you to enter top of wall and bottom of wall points. This then automatically generates the retaining wall which you can export to a pdf with some notes and a grid, etc. I would like to develop something similar but this does not need to be its own program as it would be for my use only.
I wonder if it would be worth while to use a programming language and try do the whole thing in a program editor..hhmmm...
EIT
Please forgive my terminology and general lack of knowledge here:
In excel I have equations which result in different x,y values for different poly-lines. Can I then write a program using VBA in excel to pull these vales from the worksheet and into the code/syntax needed to create the dxf file?
Or is there a better way to do this?
Also is there any particular resource that you would suggest. It sounds like saving a DXF file and analyzing it is a good way to go also I found the autocad dxf referance manual:
http:/
Thanks again
EIT
