SP 0.0
SP 0.0
I've Service Pack 0-14 but can't install without SP 0.0
Does anyone know where I can find it?
Thanks!
Thanks!
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: SP 0.0
"The attempt and not the deed confounds us."
RE: SP 0.0
HIH,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
RE: SP 0.0
I'm trying to install SP 0-14 into SW 2001 Plus... but have no chances unless SP 0.0 is installed before.
Is this problem only mine?
RE: SP 0.0
RE: SP 0.0
RE: SP 0.0
Well for
1) SW01+ is only on SP4.
2) SW01+ comes on a CD and it installs SP0.0 when you install it.
3) you can't upgrade SW01 to SW01+ with a SP you hace to have that SW01+ CD.
But to answer your question in a different way. If you are trying to install a SP for SW01 to SP14 then you need to DL the SP that fits your needs.
Example: If your using SW01 SP4 then you need to DL the SP that goes from SP4-14.
HTH,
Scott Baugh, CSWP
RE: SP 0.0
Think of SW01Plus as an entirely new program... might help to think of it as SW2002 (ok, maybe that didn't help).
RE: SP 0.0
BBJT CSWP
