HOW TO CALCULATE THE PROVIDED FLOW BY A PUMPING RING
Hello everybody,
Please, could you help me about the way to calculate the flow that a pumping ring can provide?
If I have the dimension of the pumping ring (diamater, height slots, number of slots, rpm, pressure in the seal chamber....) Which are the calculations I have to do to evaluate the flow??
RE: HOW TO CALCULATE THE PROVIDED FLOW BY A PUMPING RING
what are you trying to achieve? Design a pumping ring or calculate the efficiency of what you currently have?
I think in this forum they are people very expert in mechanical seals issues.
what I want to know is, if I have a pumping ring with straight grooves how to know the flow that can give and how I can increase that flow, for instance increasing the height of the grooves (?) or reducing the number of grooves (?),or....
That's it.
May be someone can recommend me some literature where I can find this kind of information. Only this.
regards.
Are you trying to modify an existing seal design? I would re-iterate what Flexibox stated and get your local seal supplier involved. They base pumping ring circulation estimates on not only the variables above but numerous lab tests as well to validate the calculations.
