Material to use with Urea 99% at 140 Deg, 20 Bar for flowmeter
Hello.
I have been assigned to choose a mass flowmeter to measure 99% urea at 140 Deg C and 20 bar.
I have been checking Endress+Hauser and Krohne documents,and:
E+H recommends only Ti tube for temp < 100 Deg
Krohne recommends either SS 316 or Ti for temp < 90 Deg.
However, beside that this will require the flow to be cooled; it also required to completely change the flow as I believe 99% urea flow will crystallize at temp < 135 deg or so.
I am at a loss currently as I can't find enough data on corrosivity of a rather pure urea flow. Is it even corrosive to being with?
Thanks for the help.
RE: Material to use with Urea 99% at 140 Deg, 20 Bar for flowmeter
The Outokumpu corrosion guide lists the following data.
This suggests that 317L or 904L would be suitable at higher temps as would Ti.
I would be leery of 316L in these conditions.
Urea
CO(NH2)2
Temp. °C:     180
4438 :      0
4439 :      0
904L :      0
Ti :      0
Plymouth Tube
Thank you!
May I ask if the table is referring to the pure melted Urea?
Also, what does the 0 numbers in from of the materials stand for?
Zero or close to zero corrosion.
thx, but won't that be in contradiction with both E+H and Krohne's suggestion for temp. < 100 for Titanium?
WOW!
Thanks a lot for the link, I didn't know they provide their tables online!
Based on their tables, corrosion for Standard Cr-Ni-Mo is also '0'.
I believe 316l, which is the normal stainless steel material for flowmeters tube, falls under this category?
I wouldn't.  The old European 316 ran higher chemistry than is typical in the US today.
I would step up.
Plymouth Tube
