How to calculate condensate flow in reservoir
Hey guys,
currently modelled a GAP simulation injecting gas from one reservoir into another with a 2000psi difference. With this dP condensate will be dropping out in the pipe and hence be injected into the reservoir.
I've been looking for a simple equation/model to see what happens to this condensate once it is injected. Whether it settles out due to gravity, blocks the injection face, flows to producing wells etc.
I would use Eclipse but due to time constraints am unable to do so.
Any help would be greatly appreciated.
